Originally Posted by YiffyGriffy I'm using the JSJ 10/15 BIOS that's basically the same as the Oskar 9/14 BIOS, but has up to 4.0vdimm with PSU modifications. |
Originally Posted by YiffyGriffy The only major benefit to running modded BIOSs is if you're using a Mobile or DTR processor, or are willing to overvolt your PSU so you can run more than 3.1vdimm. DFI-street.com has most of them. |
Originally Posted by Sandron19 I ordered a 3400+ clawhamer. What are some of the advantages with the modded BIOS with a DTR processor? |
Originally Posted by Evil XP2400 There's some boards that wont boot with the DTR/Mobile CPU's and the bios upgrades fix that. Also to be able to disable thermal throttling in the bios you need the hacked bios, and if you're running an SATA drive you probably wont be able to get passed 240FSB with the stock bios without crapping out on you. |
