Hi guys.
I have this motherboard and my system is in my sig.
I reset my overclock to have a test of higher memory speeds to see if that made a difference to my systems "speed".
However, i pushed a little too far and had to clear my cmos.
Now when i boot from a full power off i get the post beeps constantly, and i have to clear cmos then reboot, after which it works perfectly.
I have run Memtest for a full 100% cover of the memory (over 30 mins)
I have run prime blend for 1hr and all is well.
I cannot figure out the problem, the only thing i have found is that my power supplies -5v and -12v rails are both VERY off voltage, almost 2v under on each of them. Could this cause the problems?
Thanks for any and all help, rep will be given
