1 - 7 of 7 Posts
Ok, I'm trying to help my friend find the option to change the ma timing from 1t to 2t but we can't find it. Anyone know where it is at in the bios? Thanks
it should be under the dramm timings as COMMAND PER CLOCK (CPC) <br />
auto= 1t or 2t depending on the spid of the ram<br />
enable= 1t<br />
disable=2t<br />
<br />
edit= i think this is what your talking about
Go into the CPU frequency menu, then to the Memory Config. menu. It is Command per Clock. Either Enable (1T) or Disable (2T).
Discussion Starter #4
Ok now he got that part. He got all 4 stick of 512 in and when he starts the computer, it reads 1gb. When he goes to everest, it reads 1gb. Then, when he goes to memory, it sais 4 sticks of 512. Anyone know what's going on?
Switch to a 2T command rate <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> You can't run 1T with 4 sticks of RAM.
take out 2 sticks because amd boards dont like 4 sticks that much
1 - 7 of 7 Posts
