1 - 20 of 56 Posts
So, I did some modification to the board's northbridge cooler that takes up too much space by my first PCIe slot.
Can I install my card into the second, in single card mode, and still receive the same bandwidth? Surely there's a BIOS option for this...
thanks.
d3d
SNERP!!!
Yes
Reactions: d3daiM
Originally Posted by Snerp
Yes
In the manual it says for the corresponding slots in different modes:
SLI Mode Bandwidth:
8X - 16X PCI Express slot
N.C. - 1X PCI Express slot
4X - 4X PCI Express slot
Single VGA Mode Bandwidth:
16X - 16X PCI Express slot
1X - 1X PCI Express slot
1X - 4X PCI Express slot
2X - 16X PCI Express slot
Discussion Starter · #6 ·
So you guys are saying if I were to use the second slot it would be like this?:
When it only detects the one card...
Plug it in and then run a benchmark...you'll see
Discussion Starter · #9 ·
Originally Posted by PaRaDoX
NF4 does not have very many PCI-E lanes so you can have 2x/16x 8x/8x so just use the motherboard jumpers to enable sli and use 8x on the bottom slot
I refuse to use a lower bandwidth!
I still haven't got my answer, all sounds like speculation...
So it IS possible to get 16X on the second PCIe in single card mode correct?
The motherboard will detect it in the second PCIe and will limit the first instead?
Well, I actually am working on my board outside of my system and would like to get it finalized before I put it back in. So, if by putting my card in the second PCIe slot in single GPU mode will limit me in any way, I will have to do something about my northbridge cooler..
No, you cannot get 16x out of the bottom slot.
Take a look at your board.
there is two 16x slots a 4x and a 1x. There are 20 pci-e lanes your north bridge has. I'll let you do that math
Discussion Starter · #12 ·
yes, but what if it were to limit the first PCIe and allow the second as in 2-1-1-16 instead of 16-1-1-2..
bleh, just try it and see.
yeah I know, but that'd be less goodness for my card..
...plug it up and find out...
I don't know why you havent tried already...it would have alleviated the back and forth with our replies and your rebuttles
1 - 20 of 56 Posts
