1 - 6 of 6 Posts
Ok, what RAM's and PSU's are good working with this board? I have heard it is really picky. What brands is what I am asking.
G.SKill or OCZ for ram<br />
<br />
Get a OCZ Gamexstream PSU. 600w or 700w
I doubt it would be picky on PSUs, but as long as you have all the cables, you should be set.
The Ballistix DDR500 2x1G should also work fine. The Crucial sight has a config tool to assure that. BTW, it's on sale at the egg.
<tr>
<div>
Originally Posted by <strong>gonX</strong>
</div>
<div style="font-style:italic">I doubt it would be picky on PSUs, but as long as you have all the cables, you should be set.</div>
</td>
</tr>
</table>
</div>They are.<br />
<br />
Have to be narrative 24 pin.<br />
And have at least 480w.<br />
<br />
My psu wont cut it with this mobo. (Restart problems)
404 Title Not Found
G. Skill is great ram, I've heard it works great w/DFI.<br />
<br />
The PSU shouldn't be much problem as long as it can power your system. If I had the money right now I'd upgrade to a PCP&C, something like this:<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817703005" target="_blank">http://www.newegg.com/Product/Produc...82E16817703005</a><br />
<br />
OCZ will be a little cheaper and should work fine.
1 - 6 of 6 Posts
