1 - 4 of 4 Posts
ellllo'<br><br>
Havin problems with a DFi NF3 UT... I put a stick of G.Skill HZ (1gb) and when I boot it up, LED 6 (DRAM POWER I believe) is red and it is one constant beep.. I cleared CMOS and same thing. I tried a generic stick of PC2700 and same thing.<br><br>
Any ideas?
One long beep is ram if i remember right, so you're on the right track.<br>
Have you tried the ram in different slots?
with mine i could only use slots 1 and 3....<br><br>
try the slot near the cpu.....<br>
that board is very picky with ram<br><br>
good luck
Discussion Starter #4
Well if anyone wanted to know the problem, VGA card wasn't in all the way.<br />
<br />
Talk to you guys later I need help with some RAID BS now <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
1 - 4 of 4 Posts
