1 - 8 of 8 Posts
Ok I just upgraded to the dr and added another 6600gt, did a fresh install of windooooooooos...sli working just fine, but after I downloaded some benching software like aquamark03 and 05, I now have a thin green line running in the exact middle of screen with 2 line running up and down the left side like a graph...the more stress on card. the line widens and narrows inside the margin...and idea of what is happening?? This is only on the benching software...nothing else, and yes, I have un-installed and re-installed 3 times
I had that happen once and had to switch vid drivers to fix it. It only showed in AM3 tho for me.
it is the SLI load sharing graph. I had the same problem with mine. I am at work right now or I would tell ya where it is
1 - 8 of 8 Posts
