1 - 8 of 8 Posts
Ok guys parts just came in 2x 512 gskills ram ad dfi ultra-d mobo, question is can i use the second slot for my 6800gt? cuz if i use the first one its way too close to my xp-120 and its covering the chip set fan, do i have to set any jumpers? and using the secondary pci-e would create any problem?
no, if you want to run your PCI-E card at 16x you'll have to use the top slot - the 2nd PCI-E is only 8x or 4x i cant remmber. i know what you mean - my 7800gtx is way too close to the big typhoon and all they are dooing is heating each other up.
Originally Posted by Peroxide
Ah crap, the BT is too close to the first PCIe slot?
That really stinks, now I have to get a new board.
It's not too close, no. Just very close, so they get a little hotter.
I never actually knew that the second slot only had an 8x bandwidth. I was always just too lazy to move it once I noticed how close they were.
I think you can use the second fine. They have a shared 16x band.
You could try it if you want to. It will not damage anything.
Most people just use the first one, but I seen somewhere were the second one will work at 16x, but I have never tried it.
Ok go with Mr Mumbles
http://www.dfi.com.tw/Product/xx_pro...YPE=LP&SITE=US
Here it says 2 16x slots.
called dfi recently?
1 - 8 of 8 Posts
