DFI UT X58-T3eH8 Quick Question
614 Views 6 Replies 4 Participants Last post by  bumsoil
Can this heatsink thingy be attached to the board while it is mounted in a case? Like does it fit through the I/O shield and won't cause any problems?
1 - 7 of 7 Posts
You'll have to do some board juggling, but it'll fit. Just remember you won't be able to use an IO Shield.
Yes you can.
1. First install the mobo without the heatsink. (It's okay to install the i.o shield)
2. Unscrew the build-in i/o shield screw.
3. Install the heatsink (remember to add TIM)
4. Rescrew the build in i/o shield plate thingy.
You guys shouldn't just assume the i/o plate won't fit if you've never owned the board before : /
Reactions: 2
Originally Posted by Eek
Yes you can.
Thanks!
Are the temps noticeably different with it installed as well?
Originally Posted by Dopamin3
Thanks!
I've never ran it without the heatpipe assembly so i'm not sure how much difference it made.
But while i had it. I had remove the stock nb and installed a HR-05 IFX with a 80mm panaflo. Active cooling on the nb made a huge difference. Dropped temps by 20+ degrees
Please forgive me??
Eek said it all.
and i saw about a 10C difference without it, some people claim a 20C or more difference. so use it.
1 - 7 of 7 Posts
