1 - 4 of 4 Posts
I just got my new rig setup (see signature.) I'm running with a slight vcore bump to CPU and VTT, and within 3 minutes or so of prime95 my VRM temps are 80C??? This is with the Frame Fleezer installed and I have also mounted a Scythe Mini Kaze fan between the NB and VRM area (near USB ports) to try to cool it down with no luck.
I'm scared to let it stress longer...
Originally Posted by xdaseinx
Check your vcore. Not in mb if you're at stock, but with cpuid. You should not run your system if it goes to 80c until you find the problem.
Sigh, I honestly fail to see your point in that post. Look at the image I posted, I have CPU-Z up, along with the DFI hardware monitor Smartguardian (which reports values very close to what they really are).
All voltages are well within the safe limits AND I have specified these are the VRMs, not any other component.
This is just so frustrating.
1 - 4 of 4 Posts
