I'm running D3 on my sig rig at 4.8ghz and with my gtx 580 OC'd to 935 core / 2100 mem with 301.24 beta drivers, also tried the whql drivers. When I run the game, it looks like everything is stuttering and glitching around, not the main menu, in the game. I watch my fps and it stays high above 130, but jumps around. I tried to enable vsync via nvidia control panel for my 120 hz monitor, but it won't work with D3. So I enabled it inside of d3 and am sitting at 60 fps. The game is still stuttering and glitchy a bit.
I went into MSI Afterburner to view my temps and GPU usage during heavy encounters, its only utilizing 48% of the GPU @ 58 C. I than opened up task manager and found that I was using nearly 100% of my CPU, i5 2500k @ 4.8 ghz?!? Is my CPU bottlenecking me somehow?
CPU-z shows it properly at 4.8 ghz and all of my overclocks are stable. How can I get diablo 3 to not stutter and to utilize all of my GPU? Also, How can the game be using 100% of my CPU, is this correct?
Also, if you had a similar problem like this and fixed it, please give me any advice you have! Thanks
