Hello everyone,
I am new to this forum and to overclocking, sorry if ask banal questions.
My setup is i9-11900K liquid cooled, motherboard AsRock Z590M Phantom Gaming.
Problem:
My CPU won't boost anymore over 3.6GHz. (for a while was boosting to 4.0GHz)
After some seconds will drop to 2.5GHz (or even 1.3GHz)
Without overclock it was reaching 4.8GHz when all cores.
First time I did overclock, I managed to get my CPU up to 5.1GHz all cores.
Good temps but sometimes my PC would turn off itself. When not under load.
I did the overclock with a mix of BIOS and Intel XTU.
I then decided to reset everything and do the overclock again.
I could not get the same speeds. I tried changing TB max wattage in XTU again but it glitched.
Since then, no matter the setting in the BIOS, an aida64 stress test would crash my system.
I did reset the CMOS.
When reset to default the system does not crash but boost speeds are never over 4.GHz.
Now even I change setting, nothing seems to change. Except RAM.
XTU always shows "xtu current/edp limit throttling"
I tried to uninstall and install it again but this time it BSOD'ed my PC...
Could you tell which is more likely to have failed?
Below the config.
Thank you in advance for your help.
Sorry for the long post.
Problem:
Below the config.
