1 - 20 of 27 Posts
So it's my first time overclocking, read a few tutorials, and so i went into my asus a8n32-SLi bios, went to jumperfree, made the fsb freq 205, made the cpu freq 8.5 times and upped the voltage one knotch... did i do this right? it still says my fsb multiplier is 10x, but i changed a cpu multiplier from 8x to 8.5 x. are they the same thing?<br><br><br>
did i do everything correctly? my temp only went up 2 degrees. pc wizard says my proc can do 2 gHz but is at 1.7 gHz. so i did this all wrong?
1/2 multiplyers are odd, they effect the CPU but not that RAM.<br>
Anyway, try to get the highest OC you can @ defaault voltage, then when necessary up it a notch!
ok.. but i didn't unlock the cpu adjusters... they're unselectable. i think i changed the wrong thing <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"> what i'll do is change that back to 8 times, i'll put it back to stock voltage, and put the fsb freq to 210 from 200.<br><br>
btw specs are in sig.
Retired
I believe the 3800+ has a 9 or a 10 multiplier (if stock speed is 2.0 it is 10). Anyways, set it at its max multiplier, no reason to be using 1/2 multipliers at this point.
matty, did you look over this FAQ? Very good, not real long either.<br><a href="http://www.overclock.net/faqs/31782-how-find-limits-my-cpu-memory.html" target="_blank">http://www.overclock.net/faqs/31782-...pu-memory.html</a>
Discussion Starter #6
i'm confused... in the cpu settings it says my fsb multi is at 10x (the max as you said) but is the cpu multi different? is that the thing i was playing with earlier? i set it to 8.5x from 8 but changed that all back to auto and just put my fsb freq at 210 mHz.<br />
<br />
I'm running 2.1 gHz now, haven't tested for stability yet tho. i'm gonna do this tutorial you sent.
Retired
<tr>
<div>
Originally Posted by <strong>Mattybass</strong>
</div>
<div style="font-style:italic">i'm confused... in the cpu settings it says my fsb multi is at 10x (the max as you said) but is the cpu multi different? is that the thing i was playing with earlier? i set it to 8.5x from 8 but changed that all back to auto and just put my fsb freq at 210 mHz.<br />
<br />
I'm running 2.1 gHz now, haven't tested for stability yet tho. i'm gonna do this tutorial you sent.</div>
</td>
</tr>
</table>
</div>Yes, earlier you were fiddling with the multiplier of the CPU. Remember, CPU speeds = FSB*CPU Multi. Setting your mutilipier at 8 is actually downclocking your CPU. Now that your multiplier is back at 10, and your FSB is at 210, your running 2100 mhz, or 2.1 ghz. Your doing fine!<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> Just keep pushing that FSB up until you see instability, at that point up the voltage, rinse and repeat. Just be sure to keep your temps <55 at full load. Later on you will have to mess with your ram timings / dividers, for which I would suggest reading the FAQ linked. So far so good though, your getting the hang of it!<br />
<br />
EDIT: Im sorry, I didnt answer your question lol, yes the CPU and the FSB mutiplier are one and the same in this instance.
Reactions: Mattybass
Discussion Starter #8
oh, lol actually my cpu multi is at 8 stock, i went to 8.5 and 205 fsb but instead i lost 300 mHz in the speed. however, it says my fsb multiplier is 10x. there's two different multipliers right?<br><br>
but i'm gonna keep doing what i do, moving up in it
the multipliers you speak of are one and the same. it should be set at its stock 10x. Leave that alone at 10 for now. Raise the FSB # from 200 to 210. (take the multiplier you originally changed and make it a 10 again.)
Discussion Starter #10
ahh, just discovered after playing with that multiplier they're the same, only the one i can't adjust is just a reading <img src="/images/smilies/rolleyes.gif" border="0" alt="" title="Roll Eyes (Sarcastic)" class="inlineimg" /><br />
<br />
well, i raised the fsb to 215 and, even though the multi is 10x stock, i set it to manual and put it at 10 anyway just in case i have to lower the multi later.<br />
<br />
<br />
soooo..... do i just keep going up and up till i start get instability? i'm only at 2.15 gHz right now, i just rebooted two minutes ago and my cpu is sitting at 41 degrees C idle (my pc is always a little on the hot side but it's good) so should i go big increase? like could i safely go to 2.4? and if i do, should i just run prime95 overnite? i have about 30 minutes before i'm gonna hit the sack for the nite so i'd like to set it to get on prime95 before then.<br />
<br />
<br />
by the way thanks for all your help everyone, rep for all!
Retired
Well, that is a little high for idling, for the most part you dont want your CPU cresting 55 for extended periods of time, and certaintly not operating at 60+. I would suggest trying 220*10 for 2.2, then prime a while and see where your temps are.<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Discussion Starter #12
what exactly do you mean by "for 2.2"? so i'm to understand try going to 220 mHz, 10x FSB and the rest i didn't understand.<br />
<br />
I'm a n00b at overclocking <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" />
Retired
<tr>
<div>
</div>
<div style="font-style:italic">what exactly do you mean by "for 2.2"? so i'm to understand try going to 220 mHz, 10x FSB and the rest i didn't understand.<br />
<br />
I'm a n00b at overclocking <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /></div>
</td>
</tr>
</table>
</div>No problem. By 2.2 I mean the speed in GHZ your computer will be operating at, as derived by FSB*Multiplier, or 220(FSB)*10(multiplier). 220*10=2200mhz, or 2.2 GHz. <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
Discussion Starter #14
AHH lol <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" /> simple enough!<br />
<br />
well i will try for 2.2 and report in tomorrow morning! nite all, thanks for the help tub!
Retired
<tr>
<div>
</div>
<div style="font-style:italic">AHH lol <img src="/images/smilies/redface.gif" border="0" alt="" title="Embarrassment" class="inlineimg" /> simple enough!<br />
<br />
well i will try for 2.2 and report in tomorrow morning! nite all, thanks for the help tub!</div>
</td>
</tr>
</table>
</div>No problem, be sure to watch those temps!
Discussion Starter #16
ACK!!!!!!! <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"> I was getting many instability and my computer was getting hung up, sometimes to the point i had to power down from the psu and after setting everything back to normal, it seems my wireless NIC card is totalled somehow. it connects for a minute, then disconnects and when it's connected to my router it won't get to the internet.<br><br>
i was getting some access violation error so i reinstalled the drivers but still the same thing happens! I really need the internet on my comp! <img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"><img alt="" class="inlineimg" src="/images/smilies/eek.gif" style="border:0px solid;" title="EEK!"> Any ideas? My computer is stock speed, 200 mHz and everything else appears to load fine.
<div>Originally Posted by <strong>Mattybass</strong></div>
<div style="font-style:italic;">So it's my first time overclocking, read a few tutorials, and so i went into my asus a8n32-SLi bios, went to jumperfree, made the fsb freq 205, made the cpu freq 8.5 times and upped the voltage one knotch... did i do this right? it still says my fsb multiplier is 10x, but i changed a cpu multiplier from 8x to 8.5 x. are they the same thing?<br><br><br>
did i do everything correctly? my temp only went up 2 degrees. pc wizard says my proc can do 2 gHz but is at 1.7 gHz. so i did this all wrong?</div>
</td>
</tr></table></div>
Here are my settings for 2.6Ghz: (I would have given you mine for 2.8Ghz, but you says yours idles at 37C. Mine idles at 27C.)<br><br>
FSB: 260Mhz<br>
vcore: 1.375v<br>
HTT: 3x<br>
Divider: 166Mhz<br>
Timings: 2.5-4-4-7<br>
vdimm: 2.8v<br><br>
Try that. Leave your CPU at the highest multiplier possible.
Discussion Starter #18
lol read above posts man
Retired
Overclocking your CPU will not adversly affect any of your other hardware, atleast, not physically, thats not to say it cannot corrupt drivers and such. Also, try resetting your router, sometimes my wireless internet does that and resetting the router fixes it (I have to reset my router atleast once a month). Dont worry, you havent broken anything.<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Discussion Starter #20
i know, sometimes my internet does that too. i just disconnect the modem and router and shut down the comp, then i boot in that order and it works but this time the actual card cuts in and out... but anyway... where do i reset the router in the config? it's a linksys.
1 - 20 of 27 Posts
