Did you reset CMOS? You probably did, I'm just asking.
I'll check about the speakers.Originally Posted by logan
I'll be honest, I don't think I've ever heard of anyone doing this before. I actually have no idea what will happen if try to swap the ram while the computer is sleeping, and then is powered on.
I know that generally the ram is full of the state of the OS when it is asleep (thats generally the difference between sleep and hibernate, sleep goes to ram, hibernate goes to the hyberfile on the hard drive). So in general I'd say that I'd never expect the machine to come back from sleep correctly. I just don't know if doing so would actually physically damage the machine.
If you're not posting, thats a big deal. Are you sure your mobo has an actual speaker? many of them don't now days, so its worth checking to know if you're just not hearing them, or if they're not happening at all.
Sorry man, that sucks.![]()
I took out the battery for a few mins not 30 mins though. Also there is a jumper for clear time memory for the bios which I also tried. The motherboard is an asus 5a78l-m lx plus and has 2 ram slots. When it was in sleep mode it had only 1x4GB which I pulled out and then put 2x2GB then the computer started running after I accidentally pressed a key in the keyboard while moving it. Nothing displayed. I tried using different ram configurations and nothing.Originally Posted by Ike
Sorry about that. When you said you cleared the CMOS, did you use the Jumper or take out the battery? I would suggest taking out the battery and leaving it out for a while (30 min+) just to make sure it gets cleared. I have had it where I take out the battery for 10 seconds and my problem still exists for some reason.
Also, if you take out all of your ram your computer won't post. Try placing a single ram into a slot that wasn't being used before. (One that you didn't pull out while the computer was on) and try starting it.
Good Luck
I kind of tried that already, except taking out the CPU and putting it back again. I have a friends motherboard I will try to put cpu and ram on. Motherboard still has warranty though. But yeah I was so tired and sleepy that I forgot I left something installing and computer might have been in sleep modeOriginally Posted by wizardonthejob
So class, what have we learned?
Always unplug your computer when you are messing around inside it.![]()
First, run through the clear CMOS process again, which should go something like this:
1. Switch the jumper to the 2nd and 3rd pins (as opposed to the 1st and 2nd) and power up the computer. It may or may not post with the jumper moved.
2. Turn the computer back off and move the jumper back to 1st and 2nd pins.
alternatively
3. Remove the CMOS battery, unplug the power supply from the wall and hold the power button in for 10 seconds. This will surely clear the CMOS.
Finally, if that all doesnt work, I would try re-building the computer. Take out the mobo, even re-seat the CPU. Be sure your mobo stand-offs are tight and the mobo screws are tight as well. This gives you a chance to re-seat EVERYTHING, ruling out shorts etc.
If it still doesnt post... yea, you prob fried the mobo. Got another to try?
Good Luck!
