I got a new motherboard and CPU a few months ago--A64 3200+ and Asus K8V. All worked well, so I overclocked it 10% to 2.2 Ghz. After leaving it at that for a while, I read a bit more about overclocking, so decided to see how high I could take it.
I got Clockgen and found that it said I couldn't step my CPU voltage beyond the 1.550 it was at, but I saw an option to set that voltage higher in the BIOS. I had downclocked back to the stock 2.0 Ghz already, just in case, and proceeded to set the voltage to 1.6 volts. Then it made a funny noise and turned off.
I've trying leaving it off and clearing the CMOS, with no results. The motherboard is getting power fine, and the power supply seems to work, but whenever I turn it on, the power light blinks, and that's all. It seems that something is wrong with the CPU, but I don't have any idea what. So, is the CPU completely dead or is there some way that I can fix this?
Thanks for any help.
