1 - 3 of 3 Posts
Remove -advmethods and it should give you a better chance.
Also make sure in your config that you select big for the size of work units.
Acceptable size of work assignment and work result packets -- 'small' is <5MB, 'normal' is <10MB, and 'big' is >10MB [normal]? big
To double check just add the -configonly flag and remove when when done.
1 - 3 of 3 Posts
