Looking through the bios, it looks like I set the FSB in actual mhz. Would you happen to know if I should link and sync, or just set unlinked.....increase FSB to 1600mhz, and manually set rated speed and voltage for the ram?
Ram is rated at 7-7-7-20 1.9v 1600mhz.
I'm posting my current default bios settings below.
Not sure what spread spectrum is, but it seems most people with these boards disable all of this.
Thanks again...
BIOS Version: P07
**System **
CPU Freq, MHz: 2833.3 GHZ
FSB Reference Clock, MHz: 1333.3
CPU Multiplier: [8.5]
PCle x16-1 & 16-2, MHz: [100]
PCle x16-3, MHz: [100]
SPPc->MCP Ref Clock, MHz: [200]
nForce SPP --> nForce MCP: [5X]
nForce SPP c-- nForce MCP: [5X]
**Spread Spectrum**
CPU Spread Spectrum: [Center Spread]
HT Spread Spectrum: [Auto]
PCle Spread Spectrurn(SPP): [Disabled]
PCle Spread Spectrurn(MCP): [Auto]
SATA Spread Spectrum: [Disabled]
**FSB & Memorv Config**
FSB - Memory Clock Mode: [Auto]
FSB - Memory Ratio:
FSB (QDR), MHz: Auto [1333.3]
Actual FSB (QDR), MHz:1333.3
x MEM (DDR), Auto MHz: 1066.7
Actual MEM (DDR), MHz: 1066.7
P1: [AUTO]
P2: [AUTO]
**Memory Timing Setting**
Memory Timing Setting: [manual]
tCL (CAS Latency): 7
tRCD: 7
tRP: 7
tRAS: 20
Command Per Clock: [1T]
** Advanced Memory Settings **
tRRD: [Auto]
tRC: [Auto]
tWR: [Auto]
tWTR: [Auto]
tFAW: [Auto]
tREF: [Auto]
**System Voltages**
CPU Core: [1.19v]
CPU FSB: [1.1v]
Memory: [1.500v]
nForce SPP: [1.30v]
nForce MCP: [1.500v]
GTLVREF Lane 0: [Auto]
GTLVREF Lane 1: [Auto]
GTLVREF Lane 2: [Auto]
GTLVREF Lane 3: [Auto]
**CPU Configuration**
Limit CPUlD Maxval: Disabled
Intel Speedstep: Disabled
xPPM Mode: [Native]
CPU Thermal Control: [Disabled]
C1E Enhanced Halt State: [Enabled]
Execute Disable Bit: [Enabled]
Virtualization Technology: [Enabled]
CPU Core 0: [Enabled]
CPU Core 1: [Enabled]
CPU Core 2: [Enabled]
CPU Core 3: [Enabled]
