Difference between the P6T Deluxe and P6T Deluxe V2
505 Views 3 Replies 4 Participants Last post by  rex922
1 - 4 of 4 Posts
The only difference is the V2 has a PCIe X1 slot and the other has a X4 slot instead. That's all I notice at first glance.
They look pretty much the same.
Edit: Actually if that is the difference then the picture of the V2 board is wrong because the pict in both shows a X4 slot.
Edit2: If you're thinking about getting this board and you want a X1 slot you might want to confirm that the specs are correct.
Originally Posted by Juggalo23451
1st board DDR3 1600(OC)/1333/1066 MHz
can support up to 12 gig of ram
2board DDR3 2000(O.C)/1866(O.C)/1800(O.C)/1600(O.C)/1333
can support up to 24gig ram
thats the most major difference
1 - 4 of 4 Posts
