Are you using all 4 gigs? If you arent then it wont make a lick of difference. If you are maxing out the 4 gigs then yes, you will defiently see an increase in performance.
If you do not have some specific need for that much ram, like you work for crytek and you need to make crysis levels or something, then maybe. Otherwise, no it will make no difference at all. Might even slow ur computer down slightly.
Slightly related note as far as whether or not it's worth it - for my DDR 3, I ended up with 5x2gb sticks. With all 10gb in, I don't get as good of performance as with 6gb. If you have ddr3, better to have 3 or 6 dimms. ddr2, 2 dimms or 4 dimms.
Correct me if I'm wrong, but I'm pretty sure that has nothing to do with DDR2/DDR3 RAM, it's the Dual/Triple channels that govern what performance your RAM performs at. So if you're on an X58 platform, get an odd number of DIMMs. Even for LGA1156.
Correct me if I'm wrong, but 1156 is Dual Channel, hence even number of DIMMs. i7 1366 is only Triple Channel.
