Differences on EVGA 7800gs models?
1829 18
I am looking to purchase one of the EVGA 7800gs agp cards.
The question I have is:
What is the difference between these two cards? Is it just being overclocked? No software or hardware differences?
E-GEOFORCE 7800 GS CO SUPERCLOCK (PART NUMBER 256-A8-N509-AX)
AND
E-GEOFORCE 7800 GS CO (PART NUMBER 256-A8-N506-AX)
Also what is the difference between the reference fan and the egva fan?
Any hardware/software/cooling/fan differences?
Thank you!!!
1 - 19 of 19 Posts
just overclock which you can easily achieve via .. riva tuner or nvtweak or whate ever... its just overclock man... the 7800gs egs or whatever it is is exactly the same as all the others its cheaper same everything but the higher models are just overclocked get the cheapest one and you can easily overclock to 460/1.35ghz easly if not 480/1.4ghz
I believe the superclocked version comes with a copper heat sink, which dissapates heat more effetively than the regular heatsink.
Ones overclocked more than the other, so im going with the 7800GS CO.....no real big oc' besides the 2 cant wait till i order mine....
Yea I think they did put a better HS on the OC one.
Originally Posted by GatorLCA
Both the cards have a Copper heatsink so go with the one that is cheaper with the same heatsink and OC it, more than likely you'll get the same clock speeds by using a program.
Don't get the SuperClocked one, waste of money since OC'ing is pretty easy, especially with CoolBits
But why would you then spend $30 on a aftermarket copper HS/F when you could have one built in for $20 more?
Believe it or not the Copper heatsink they put on it is actually quite good..allows you to to not have to buy an extra cooler. Also, what decent AM cooler can you get for $20 shipped. The only ones you should look at are the Arctic Cooling's and the Zalmans and those are $35-$40
Plus the ones with Copper coolers are typically clocked higher than vanilla ones, now if the clocks were the same I'd say just get the vanila one and put a new cooler on but eVGA has a damn nice coper cooler
Plus at Newegg the Copper version is only $10 more and clocked 75MHz higher.
Originally Posted by FoRmEd
I'm going to Hooper Ut...
I lived there for 8 years before I joined the Marine Corps...
I'm getting out and moving back...
Looking forward to the Snow!
I edited my last Post, if you want I can give you a link!
Oh yeah? I know folks in Hooper, know the area. My wife was living there when I met her. Her parents still live there.
So for the 1.4 ns ram and 1.6 ns ram, is the lower number better for overclocking then? 1.4 ns, that in relation to speed isn't it?
thats how im looking at it.1.4ns should overclock to about 700mhz minimum and 750 more likly after overclocking to the max..
K4J55323QG-BC12 800MHz 1.6Gbps/pin Pseudo Open Drain_18 136 Ball FBGA
K4J55323QG-BC14 700MHz 1.4Gbps/pin
K4J55323QG-BC16 600MHz 1.2Gbps/pin
K4J55323QG-BC20 500MHz 1.0Gbps/pin
so if this is the case then the memory on the cheapest model should be able to overclock higher. yeilding a higher Gbps.....
1.6 is rated for about a max of 625mhz (1250mhz)where as the 1.4ns is being OC'd to about 725mhz(1450mhz)
Discussion Starter · #18 ·
One more quick question:
Between these three models I am seeing and hearing these differences from forum groups:
7800 GS CO Superclock (EGVA fan N509) 1.6ns memory , CineFX 4.0 engine, Intellisample 4.0
78800 GS CO Superclock (reference fan N508)
7800 GS CO (Evga fan N506) 1.6ns memory, CineFX 3.0 engine, Intellisample 3.0
7800 GS (Reference fan N505) 1.4ns memory, CineFX 4.0 engine, Intellisample 4.0
Is the 1.4ns memory better? I am hearing the lower this number the better overclockign potential it has? If so why is the Superclock card at 1.6ns memory? And why would the (N505) with the 1.4ns memory be the cheapest card?
Also, what is the difference between the 3.0 and 4.0 versions of the CineFX and Intelisample?
Which cards have the better copper heatsink?
Which card is the overall best if i want to overclock it myself for the fastest speed?
Discussion Starter · #19 ·
Just in case anybody is interested:
I called EVGA and spoke to one of their techs tonight. Very nice fella! Anyway, he has clarified this for all of us:
All 4 7800gs cards that they offer are at 1.4ns memeory response time. The 1.6ns was a typo.
Also, three out of the four cards state that they have CINEFX 4.0 and INTELLISAMPLE 4.0. The 7800 GS CO states it has 3.0 versions of these. This is also a typo. All four cards have the 4.0 verisons.
The other thing he clarified is that the 3 cards with "CO" in the model title have better copper heatsinks, while the bottom of the line 7800gs (model N505) does not.
There you go! So in conclusion and to affirm what a lot of people have told me, buy the 7800gs CO (model # N506) with the evga fan (got mine for $299 with free shipping from circuit city) and overclock it yourself and save the dough!!!!
Thanks to everyone for their advice and help on this!
1 - 19 of 19 Posts
