hi, i have those ssd in my list for buying it but, what are the diferences between them
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148526 (3,5 adapter)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148530 (7mm)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148443 (nothing else, only the ssd)
are the differences only what i mention on the "( )" ???
do you think that is a good option to pay a little more for the cloning app and using it? or doing a clean install for the ssd is better?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148449 (transfer kit)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148534 (transfer kit + 7mm)
my notebook has a normal 2,5 slot, but is a good option going for the 7mm drive for future froofing??
and how they perform against the mushkin?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820226226
thanks in advance and sorry for my bad english, i'm from Uruguay
