1 - 4 of 4 Posts
i'm looking to add another 4gb of ram to my system. however my current ram has been discontinued. i have found ram of the same speed, same timings, same make, pretty much same everything just actually different ram. i just want to know whether it will work properly in my system.
thanks in advance
404 Title Not Found
It should work fine, just can't mix and match the channels with different ram sticks. If your current ram is in dual channel just add the other two sticks in the empty slots.
I've seen people run 2 different manufacturer's RAM on the same system...as long as they're the same speed, timings and voltage requirements, it should work fine
I'm assuming it has to have the same IC's as well..ie can't mix Micron with ProMos
1 - 4 of 4 Posts
