1 - 3 of 3 Posts
hi friends
i want to know does any diffrence between these two graphic's in full hd tvs? i mean image quality
if there is diffrence i change my 5750 if not i dont change.
thanks
Image quality is identical. the 5770 will be about 10-15% faster on stock clocks. It depends entrely on what you are doing, but unless you are playing games like STALKER, Crysis, etc. or overclocking heavily, the 5750 is a better value.
That is with both at MSRP though. If they are within $20, get the 5770 for gaming.
Make sure whichever one you get is 1GB VRAM.
Source: I have both.
Turtle Lives Matter
I own a 5750 so I can only tell you I can overclock up to 5770 speed, stable and cool. I use a 1920 x 1080 resolution.
The main benefit of a 5770 over a 5750 is that they have software voltage tweaking so they can overclock very easy ~1GHZ.
They both typically get same memory OC at around 1350, rarely 1400.
1 - 3 of 3 Posts
