So as you may or may not know, the northbridge on the 890FX (AM3) Northbridge get pretty toasty. And for those of us with early versions of the Crosshair IV Formula, it gets hot enough to sometimes shut itself down because ASUS really had to take a piss and got really distracted with what they were doing, and they didn't seat the heatsink properly.
At idle it sits around 45ºC with 2x40mm fans blowing directly on the heatsink. At ambient of 22ºC. When gaming it can go to 50ºC (which is still OK but it's gotten to 60ºC when trying to push the CPU to 4.5GHz)
I'm wondering if it would be possible to Direct Die a TEC on the NB and SB (just hypothetical because the SB is really crammed in tight) I did a little reading on Wikipedia, saying the TDP of the NB is about 20W so the heat being moved is definitely possible, but I'm wondering if condensation could get underneath the chip and wreak havoc, or is it air tight under there, as it is directly fastened to the board.
EDIT: This is all just hypothetical and really isn't practical. But if you feel like answering, please do.
