1 - 8 of 8 Posts
· Linux Guru
Originally Posted by milkybar
which is the best way for the fan to blow on the heat sink?
as i can tell mine blows away from the heat sink is this wrong cos thats how it came from the supplier
It must blow the cool air onto the heatsink.
Originally Posted by Evil XP2400
Always blow in... And that's a volcano 11 so I'm even more certain that it should be blowing in... Flip it! even if you dont have temp problems, they should drop once you get the fan blowing the right way.
right i flipped the fan and now its blowing down i even used artic 5 on me cpu while under the bonnet now im idel at 39 0c not gon on full yet but its droped on the idel ty guys
· Premium Member
It could have been 'bouncing', for example, I set my tornado facing down on top of the heatsink to blow onto the sink, and I put my hand over the fan and felt air blowing onto my hand... But it WAS blowing down, so make sure 100% that you have it correct
Discussion Starter · #8 ·
Originally Posted by nayo_450
"bouncing"?
he means the air was coming back of the heatsink and hiting his hand yeh i checked the arrows on the side of the fan and they are the correct way now maybe some just had a bad day when building it lol
1 - 8 of 8 Posts
