Hi, guys,
Quick noob question.
I am going to be mounting a '77 Bonnie Heater Core on the top of my Antec 900 case, sitting in a Performance Shroud, about an inch above the honeycomb grill.
Is it OK to mount the HC with the barbs pointing down? It reduce the length of the loop overall by probably 18" or so.
Attachment 146413
thanks,
EDIT: looked around some more and found plenty of examples of top mounted rads with the barbs pointing down, so I'm pretty sure this isn't an issue, just thought it was worthwhile checking with the experienced masses.
Attachment 146413
thanks,
