1 - 17 of 17 Posts
Is it worth waiting for DirectX 10 to come out or should I just get a video card now?
<tr>
<div>
Originally Posted by <strong>squwish</strong>
</div>
<div style="font-style:italic">Is it worth waiting for DirectX 10 to come out or should I just get a video card now?</div>
</td>
</tr>
</table>
</div>What motherboard do you have? Is it AGP or PCI-e?
Discussion Starter #4
<tr>
<div>
Originally Posted by <strong>MjrTom</strong>
</div>
<div style="font-style:italic">What motherboard do you have? Is it AGP or PCI-e?</div>
</td>
</tr>
</table>
</div>Right now--AGP (FX5200)
well i doubt there will be any agp dx10 compatible cards, new dx api might aswell be with the new technology <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
There won't be any AGP DX10 cards, most likely. You would need a new motherboard, and probably CPU. If I were you, I'd make an upgrade to a decent AGP card, like the 7600GS, and then save up for a complete rig overhaul.
Goodbye
I'd recommend the new 7600's coming out for AGP or an X1650Pro or X850Pro<br />
<br />
The 850Pro has raw power but no HDR or SM3.0, still a great card.<br />
<br />
Otherwise I'd go with the X1650Pro
Discussion Starter #8
If I were to get this now <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813123257" target="_blank">http://www.newegg.com/Product/Produc...82E16813123257</a><br />
will it work with DX10 cards?
yep <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
<tr>
<div>
</div>
<div style="font-style:italic">If I were to get this now <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16813123257" target="_blank">http://www.newegg.com/Product/Produc...82E16813123257</a><br />
will it work with DX10 cards?</div>
</td>
</tr>
</table>
</div>Should do.<br />
<br />
The prerequisites for DX10 are PCI-e and Vista.
Administrator
<tr>
<div>
Originally Posted by <strong>Penicilyn</strong>
</div>
<div style="font-style:italic">I'd recommend the new 7600's coming out for AGP or an X1650Pro or X850Pro<br />
<br />
<br />
Otherwise I'd go with the X1650Pro</div>
</td>
</tr>
</table>
</div>The 850 has got HDR just SM2 version of it.
<tr>
<div>
Originally Posted by <strong>ENTERPRISE1701</strong>
</div>
<div style="font-style:italic">The 850 has got HDR just SM2 version of it.</div>
</td>
</tr>
</table>
</div>Thats only in the games that support SM2 HDR, CS:S/HL2 is the only one I think. <br />
<br />
Unless you want to spend $700 on a DX10 card when they come out, just get a nice 7 series or X1900 for now, you can use that for a year and save up for a new rig then upgrade to DX10.
Administrator
<tr>
<div>
Originally Posted by <strong>JacKz5o</strong>
</div>
<div style="font-style:italic">Thats only in the games that support SM2 HDR, CS:S/HL2 is the only one I think. <br />
<br />
Unless you want to spend $700 on a DX10 card when they come out, just get a nice 7 series or X1900 for now, you can use that for a year and save up for a new rig then upgrade to DX10.</div>
</td>
</tr>
</table>
</div>As far as i know yes there the only ones supported.
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>That is a great board! I have one and have had no problems with it. It has great OC'ing features etc....!!
also, i dun think DX10 games will come out so soon, u should be able to use a DX9.0c card for about 1 year before a switch to DX 10 is necessary
I would say that you should wait - whether or not you go dx10. once the new cards come out prices on old will drop like never before - since they will all be obsolete instead of just not as good.
1 - 17 of 17 Posts
