1 - 4 of 4 Posts
Hey guys, I was wondering if there is a way to disable the notification that pops up in the middle of the screen that says I switched to battery or that my laptop has been plugged in. Is there?
There is an alarm setting in control panel>power options on my xp laptop
so there should be something similar w7.
I hope this information helps
Reactions: mth91
Look in control panel\\system and security\\power options\\Change power options\\advanced (I think, it is the bottom left side) and it lets you change the notifications for low power and such.
Or you can right click the task bar, select properties, then there is a tab in the middle (Notification) and you can turn off the battery icon and notifications.
If your talking about just the balloon notifications, go to -> Control Panel\\System and Security\\Action Center\\Change Action Center settings and there should be a power setting there (don't remember for sure since I don't have a Windows 7 laptop available). Uncheck it and no more balloon tips
My netbook has never had the pop up when switching from batter to plug, and as far as I remember, I did not change that.
1 - 4 of 4 Posts
