1 - 6 of 6 Posts
Has anyone ever take a part the antec 900?
I worry that i might not be able to put it back together once it fall apart
I saw some rivets that held the case together, do you replace those rivets with screw once you took them off?
Originally Posted by Silver_WRX02;12046679
u mean taking off the hard drive/front fan mounts? or the top 200mm fan and power/reset/usb panel?
as down to top, bot, front, back, left, and right panels
so that i could paint it
Everything pops off. At least all the black pieces do. The top's a bit of a doozy but all you need to unscrew, if memory serves, is the large top fan's ground wire that's attached to the underside of the top of the case.
1 - 6 of 6 Posts
