1 - 18 of 18 Posts
<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> my ol cpu block (mounted on my vga card from a evercool wc 201 set, not the one in my avatar)sprung a leak dripping all over my X-fi... and,yes it stopped working,........dried it up gone to the store, an said "it stopped working" and they replaced it..... put it in and no problem with the sound, but BSOD's all the time....i had the original cooler mounted on my 7600gt with ceramic paste, and because of the high temps, (78c load) removed the card again and i noticed some green oxide on my pcix connector<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> wiped it, and the slot of with alcohol, and its workin fine now besides the temps (73c) used AS5 on the original (very noisy) cooler but im glad everything works......<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> should i buy a new vga waterblock (had temps of 53 load oc'ed to 666 noiseless)or get aircooling<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> .......and if yes what block/air cooler, i hate a noisy pc (recording purposes) so very lownoise please....<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" />
thats why i like air
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835118001" target="_blank">Air Cooling</a>
Air is your friend<br />
<br />
H2O + PC + random inexplicable leak = disaster <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
<tr>
<div>
Originally Posted by <strong>RuSo</strong>
</div>
<div style="font-style:italic"><img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> my ol cpu block (mounted on my vga card from a evercool wc 201 set, not the one in my avatar)sprung a leak dripping all over my X-fi... and,yes it stopped working,........dried it up gone to the store, an said "it stopped working" and they replaced it..... put it in and no problem with the sound, but BSOD's all the time....i had the original cooler mounted on my 7600gt with ceramic paste, and because of the high temps, (78c load) removed the card again and i noticed some green oxide on my pcix connector<img src="/images/smilies/eek.gif" border="0" alt="" title="EEK!" class="inlineimg" /> wiped it, and the slot of with alcohol, and its workin fine now besides the temps (73c) used AS5 on the original (very noisy) cooler but im glad everything works......<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> should i buy a new vga waterblock (had temps of 53 load oc'ed to 666 noiseless)or get aircooling<img src="/images/smilies/confused.gif" border="0" alt="" title="Confused" class="inlineimg" /> .......and if yes what block/air cooler, i hate a noisy pc (recording purposes) so very lownoise please....<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /></div>
</td>
</tr>
</table>
</div> That's why you shouldn't buy cheap WC gear it's junk,,,<a href="http://www.svc.com/mcw60-b.html" target="_blank">Swiftech MCW60 Extreme Duty VGA Bare Water Block (3/8" and 1/2" barbs)</a>
Reactions: RuSo
Discussion Starter #6
<tr>
<div>
Originally Posted by <strong>ira-k</strong>
</div>
<div style="font-style:italic">That's why you shouldn't buy cheap WC gear it's junk,,,<a href="http://www.svc.com/mcw60-b.html" target="_blank">Swiftech MCW60 Extreme Duty VGA Bare Water Block (3/8" and 1/2" barbs)</a></div>
</td>
</tr>
</table>
</div>lol yeah......i know now<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> i'm gonna check if i can find this block in my country......
<tr>
<div>
</div>
<div style="font-style:italic">lol yeah......i know now<img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> i'm gonna check if i can find this block in my country......</div>
</td>
</tr>
</table>
</div> Hope you can..<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />.. I forget sometimes how hard stuff is to get oversea's, but it's still true, the cheap kit's, as unfortunently you have found out are comp. killers.. Much better to stay with high end air then those...Best of Luck to you......
<tr>
<div>
</div>
</td>
</tr>
</table>
</div><br />
get the Dangerden Maze4 Block instead <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
<tr>
<div>
</div>
<div style="font-style:italic">can you take it apart for cleaning purposes?</div>
</td>
</tr>
</table>
</div> Oh yeah, Just take the 4 screws out...With the Swiftec ...
<tr>
<div>
</div>
</td>
</tr>
</table>
</div>Ditto, just get a Maze4 and all your problems (well not <i>all </i>your problems) will be solved. <img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /><br />
<br />
And there's always air, as mentioned above. But seriously, taking shortcuts eventually come back to bite you in the @$$ so I hope you've learned to use quality parts from here on forward. Good luck getting back up to speed.
<tr>
<div>
Originally Posted by <strong>Transonic</strong>
</div>
<div style="font-style:italic">But seriously, taking shortcuts eventually come back to bite you in the @$$ so I hope you've learned to use quality parts from here on forward.</div>
</td>
</tr>
</table>
</div><div style="margin:20px; margin-top:5px; ">
<tr>
<div>
</div>
<div style="font-style:italic">but it's still true, the cheap kit's, as unfortunently you have found out are comp. killers..</div>
</td>
</tr>
</table>
<tr>
<div>
</div>
<div style="font-style:italic">That's why you shouldn't buy cheap WC gear it's junk</div>
</td>
</tr>
</table>
</div>I agree that in general the more expensive equipment is better quality, but I must dispel this myth about cheap = crap...<br />
<br />
I have run a BigWater SE kit (very cheap) for, what must be now coming up to two years and I have never had any problems with leaks of any kind. I am currently running the same system (augmented by a second radiator) in my dedicated folding PC, 24 hours a days, 7 days a week and again, absolutely no problems with all the cheap components in the H20 cooling kit... The tiny pump is even coping with a greater length of hose and an additional radiator and still there are no problems, at all.<br />
<br />
The bottom line is that cheap does not have to equal crap. There are no doubt plenty of people who have expensive H20 cooling equipment who have also had leaks occur. Leaks are not inherent to cheap H20 cooling equipment.<br />
<br />
Admittedly, the more expensive equipment usually provides better performance than the cheaper equipment, but it is a fallacy to suggest that you must buy expensive to avoid equipment failure; in this case leakage.<br />
<br />
Highly-Annoyed
Discussion Starter #14
is this any good?<br />
<br />
<a href="http://www.alternate.nl/html/product/details.html?artno=JZZ%2344&showTechData=true" target="_blank">http://www.alternate.nl/html/product...wTechData=true</a>
SNERP!!!
<tr>
<div>
</div>
<div style="font-style:italic">is this any good?<br />
<br />
<a href="http://www.alternate.nl/html/product/details.html?artno=JZZ%2344&showTechData=true" target="_blank">http://www.alternate.nl/html/product...wTechData=true</a></div>
</td>
</tr>
</table>
</div>is the sky red? <img src="/images/smilies/whistle.gif" border="0" alt="" title="Whistle" class="inlineimg" /><br />
<br />
jk...I wouldn't buy a zalman block. They make good air coolers, but they are lacking on the water.
lol want a Maze 4, send me money via paypal, ill buy it for you and ship it to you.<br />
<br />
Ive done that alot on another forum.<br />
<br />
lol PM if your interested. I can provide credentials
Get <a href="http://www.frozencpu.com/products/1265/cas-339/Cooler_Express_Hydra_SLI_Phase_Change_Triple_Evaporator_Hyper-Cooling_Unit_1_CPU_2_GPUs_-_FREE_ALPHACOOL_KIT.html?tl=g41" target="_blank">this</a> if you have the money =D
1 - 18 of 18 Posts
