bump
Actually, i just upgraded my rig (1100t, crosshair v), and since doing that (and reinstalling win7+using a driver app- drivervwhiz) haven't had any errors. Still running the same timings.Originally Posted by HiroPro;14780229
AMD cpu's have a very finicky memory controller. That crazy timing RAM is your issue. Try to set them to more standard timings and your issues will go away.
umm, what??Originally Posted by jackthetripper
It seems, that 4101 in windows7 and vista is caused by power supply problem. Workaround:
Set the card from adaptive power (power saving) off to maximum performance. Shut down the computer.
While power off, disconnect your cable from the video card to the monitor. Start the computer and connect the cable
after you have logged to windows.
This works with latest drivers. Even with aero enabled. BF3 and flash videos on firefox running - everything is smooth, no problems anymore.
This whould be easy to fix, nvidia. I am looking forward an QUICK fix for the power usage on startup now that we know the reason.
Please try and post your trial here. I do accept a new laptop for award![]()
http://forums.nvidia.com/index.php?showtopic=215496&st=60&gopid=1350766entry1350766
