That's bascially what I use but with the addition of a few drops of PT Nuke.
Originally Posted by jws2346 ![]() This info may be wrong, but here's the way I understand it. I got this information from several forums including [H]ardOCF, XS and of course this one. The posts were written by people I know for sure know what they're talkin' about. Pentosin or any type of anti freeze (ie corrosion inhibitor) is only required if you mix different metals in your loop or if you live outdoors in the Artic ![]() ![]() ![]() Now with all that crap. I run two 24/7 Q6600's DCing ([email protected] GPU2 and WCG). Both have bowed Apogee GT's, both have MCR220 rads and both have MCP350 water pumps. One has a MCW60-R WB on a eVGA 8800GS VGA card. The other is just the CPU loop. (no mixed metals) On the boxen with the CPU + GPU WB's I didn't have any PT Nuke so I just run Pentosin (G11) for the cool blue color and a drop of Dawn liquid dish soap. I haven't had the first problems with either loop (my boxen are in my bedroom out of direct sun light). They run pretty consistently and have run for at least six months or more. ![]() I've even run loops with just QFC distilled water and I only use Pentosin for the color and the chance that'll help lubricate my pumps. ![]() DCing for the CURE |
Originally Posted by ML Infamous ![]() From everything I've read and been told I came up with: Pentosin - Every 40 ounces of distilled water add four ounces of pentosin, ..Credit goes to Ira-k for the help |
Originally Posted by unleaded91 ![]() Okay.. Thank you..that is good to know..Maybe I will just get the Pentosin g11 from an auto shop and use it as my coolant instead of using distilled + PT nuke. |
