1 - 5 of 5 Posts
when i try to run some things like benchmark 06, or even my calculator i get an error saying,<br><br>
The system DLL user32.dll was relocated in memory. The application will not run properly. The relocation occured because the DLL C:\\WINDOWS\\system32\\SHELL32.dll occupied an adress range reserved for Windows system DLLs. The vendor supplying the DLL shoiuld be contacted for a new DLL.<br><br>
what can i do? i cant even install some things...
I prefer a direct method to adress these issues. Run AV, antispyware, format system partition and reinstall windows. I have this reflex since win98: when I see a .DLL error (specialy user.dll, run32.dll, kernel32.dll, etc) I format, reinstall and in an hour it's as good as new.
Thats of course if you dont have 100gb or more stuff to backup first. Then it suxxors the big 111.
Discussion Starter #4
i cant reformat because i have alot of important info, no other way? its about 70gbs of info that i do need
1 - 5 of 5 Posts
