Status
Not open for further replies.
21 - 40 of 70 Posts
Discussion Starter · #21 ·
Yeah there are these people that are like hell bent on convincing others of just crap
I mean I dont plan on having many 90 or even any most likely, but seriously from the get go I was just like how in the hell could this possibly actually significantly impact performance...
Jesus christ...
I wouldn't worry too much about elbows in the loop. I have a lanig D5 in my loop and quite a large amount of 90 degree turns. Plus add the fact of having three rads. which are essentially a large collection of 180 degree turns. My flow is quite sttrong and pushes up a decent fountain in my res. as it returns.
You can see a series of 4 90's right off of the cpu block. I had to do this to complete such close proximity block linking.
In summary, do what every you want,but keep 90's a little distance from the pump inlet and outlet
My
Originally Posted by ZytheEKS View Post
Actually most radiators use a dual pass U flow system, so half of the tubes are all running in parallel. The combined area of the chambers running in parallel is usually quite a bit larger than the tubing you are using, and the chambers themselves have no bends or curves, but rather the chambers at the end create the U flow. This means most radiators will add little to no restriction to a loop
THEN there's the radiators that use tubes with 180 degree turns instead of chambers and charge 3x more money , because **** logic, that's why!
Quite true... I was referring to the latter in my post, but I guess I should have specified... my alphacools are definitely less restrictive than my tubing. I should have been clearer.
Umm, I definitely get more harmonically balanced data transfers with slightly more musical IOPS with my Titanium Unobtanium alloy SATA cables, and they were a blessed by the Angolian Monks of The Order of the Scambodians....
Let's not forget the mystical rejuvenating powers of reindeer urine in a water loop. It's the best way to go, no, the ONLY way! The rest of you just don't know any better
Originally Posted by DiGiCiDAL View Post
That's what I've been doing wrong... I was using Chilean llama urine in mine!
Sub-ambient water temps here I come!
I just vent the heat into an alternate dimension using a quantum warp relay. Sub ambient? ***** I get sub-absolute zero temps! Because seriously, **** LOGIC!
Ah, yes, the elusive Dimensional-Warping Molecular-Level-Thermologically-Balanced Carbon Nanotube Hexaduple Quad-Phase 17-Parallel-Dimension Quantum-Tunneling Space-Fabric Rift block, with its accompanying Anti-Gravity Einsteinium-alloyed Magnetorheological Sub-Zero Kelvin Thermal Interface Material...
I heard that it recently beat out the popular Unicorn rainbow-poop and Ground-Up Leprechaun 50:50 pre-mix as the best performing cooler...? Any truth to this?
Well with my current overclock my computer runs so fast it actually dials back time while it's loading when I click on something, so it opens before I actually click it, and I'm getting about -75kelvin as far as temps. How does the rainbow-**** and leprechaun perform under the effects of temporal manipulation?
Guys, I'm adjusting PLLs and SA and no matter what I do I can't activate the Stårgåte or get the double rainbow going. What am I doing wrong?
Needs more cowbell I think.
Have you installed the flux capacitor and rewound the F.T.L. E-Zo coils?
THREAD OF THE YEAR, RIGHT HERE FOLKS!
Sorry, my bad was low on LN2
Who still uses LN2? You need to upgrade to liquid helium man, that's where it's at!
21 - 40 of 70 Posts
Status
