Status
Not open for further replies.
61 - 70 of 70 Posts
Originally Posted by dealio View Post
i believed that could be reversed engineered from this
+1 Rep, I'll have to remember this when I'm in the marines!
Originally Posted by nleksan View Post
It clearly states that it is "INTER-DIMENSIONAL Cold Fission", which negates the paradox by simply being so convoluted that it can't logically justify itself to NOT function...
-snip-
Now who's laughing at who, huh NASA?
I'm pretty sure at this point, that NASA isn't laughing at anyone... they simply can't afford it.
They're still laughing at the North Koreans
Then again, who isn't laughing at them?
Originally Posted by fragamemnon View Post
Gentlemen...
I am disappoint.
You speculate and theorize with all that inter-dimensional cold fission when clearly you have not fathomed the ways of the Continuum Transfunctioner (whose mystery is only exceeded by its power as you should know).
Talk about ******* logic now, right? It all makes sense.
However, do not be mistaken. I still have faith in you!
_________________________________________
I subscribed and therefore I shall now remain silent, lurking in the shadowy corner of this thread, observing how you grasp the knowledge bestowed.
But you forget, the Continuum Transfuctioner requires a superconducting-sublimation based phase change heat vacuum to adequately remove heat from the Negatively-charged Ionic warp relay so that it doesn't overload the primary trans-electric coils! Working with that delicate of equipment is dangerous when employing the Temporal-Manipulation of the Croniton robbing centrifugal heat sink! To maintain a stable flow of time with such equipment you'd need a depleted antimatter isotope of U-238 oriented in a nano-tube based orientation to properly divert the flow of cronitons away from the CPU in order to accurately to shield the catalyzing warp-chamber above the centrifugal-heatsink or else you could warp your entire CPU's temporal-manipulation and make time travel FORWARD while your CPU is loading, making it take LONGER to load things than it would even without the overclock
You must remember, most consumers can't afford the antimatter croniton shields, and why would you want to? With that price you could simply employ the trans-dimensional anti-matter phase manipulation warp blocks, which outperform ANY of the things were talkin' about
of course then you need to worry about radiation
Whoa, this is some Star Trek level techno babble.
And I mean the real, old school Star Trek.
Not at all my good sir, you just need to do a little research and everything you find will be supported by science! See the croniton robbing centrifugal-heatsink not only works as an acoustical decompression based heatsink actively moving heat from the CPU to the cooling apparatus, but it also can strip cronitons from the area surrounding the CPU causing time to move backwards while it's loading. Put simply, the more heat that's moving from the CPU to the cooler the more it will dial back time while it's loading! Of course he's talking about the method that pushes anti-matter based cronitons THROUGH the CPU, which has the same general effect, except they tend to be harder to control so unless you can keep them from freely flowing around your PC chassis you don't know WHAT way time will be moving in there
however it also allows for the centrifugal heat sink to move MUCH more heat
Except when they tried to film us, our brains exploded their cameras.
OK, This thread has run it's course! All OT now.
61 - 70 of 70 Posts
Status
