1 - 8 of 8 Posts
Yeah just try reseating again, I'm sure the TIM probably got one sided or too little/too much was added. Just a little pea should do the trick. Remember TIM only helps to fill in the holes that are made from the imperfections on the surface of the copper and cpu.
4GHz
Make sure nothing's in the way of the CPU and the cooler base. That means checking your mounting system to make sure screws aren't pushing the cooler base from the CPU.
Also, make sure the fan's running, all screws are tightened to the farther they can go, etc, etc.
1 - 8 of 8 Posts
