Do I have Enough Power?
382 Views 7 Replies 5 Participants Last post by  Megaman_90
I was thinking of upgrading my CPU to a Phenom X4(125W). With my current setup, is 500W enough power to run it?
Also I need a good cooler recommendation, one that will fit on my M-ATX Mobo.
Thanks in Advance,
Mega
1 - 8 of 8 Posts
Definitely. I would get a Phenom 2, although I would first make sure that it is compatable with your board.
yea you're fine
The Rosewill Stallion 500W usually can do 300w on 12v so you should be fine.
yes you have enough power coz your megaman! don't forget to leave without rush.
lol
seriously, you'll be alright with the upgrade.
lol
Haha, I laughed at that one.
Thanks for the advice fellas, + rep for all.
Also any of you know of a good AMD2+ cooler, that will fit on a MATX Mobo?
what's the width of your case? here's a good short hsf that will surely fit in.
http://www.newegg.com/Product/Produc...82E16835103046
here's the review
http://www.frostytech.com/articlevie...id=2288&page=4
oh yeah if you're thinking about going a phI quad, ph2 tri is faster, cooler and more efficient for the same pricerange.
Yeah I think I will get a Phenom II X4, AMD CPUs are cheap anyway getting the best one won't be too much more.
1 - 8 of 8 Posts
