my problem is i cant do any of thisOriginally Posted by Sean Webster
Best to reinstall, but you don't need to, as long as you have a retail copy of the OS.
If Windows is OEM, then you need a new product key for the OS.
What to do:
I've done it a few times with Windows 7 and I never had an issue.
- Uninstall the graphics card drivers before (CCC)
- Uninstall all the motherboard drivers you can as well.
- You should make sure the UEFI in the new mother board is set up properly (SATA mode is the same as the old mobo. ex AHCI if old install was AHCI)
- If you can not boot then pop in the windows installer disk (if you have to) and use start up repair and that should fix it.
Have you tried troubleshooting to make sure it's really the mb and not say, a bad stick of memory, or monitor?
ok thank you, i will do this. Would you mind explaining what SATA mode is?
yea i did some what and gave up. I tried swaping monitors (which did nothing), but didnt swap ramHave you tried troubleshooting to make sure it's really the mb and not say, a bad stick of memory, or monitor?
I see, have you tried installing your gpu in a different slot?Originally Posted by 2tired
problems staarted happening after i realized my fan controller wasnt hooked up and my vid card over heating. Games would crash, then eventually nothing would show up on the screen. I swapped gpus to no avail, so im going to try the mobo now
