Do i need a new psu?
495 Views 14 Replies 10 Participants Last post by  boss_da_man
hello
I'm upgrading my cpu (to a e8400 might try for 4ghz) and gfx (GTX 285)
The specs.
Intel Core 2 Duo E6300 OC at 3GHZ
Asus Geforce 8800 GTS
G Skill F2-6400CL4D-2GBPK OC
WD 320,500 and 1000 GIG SATA 16mb
I'm running a 525 watt power supply. The specs of it below
AC INPUT 115/230VaC 50-60Hz 9/6A fuse Rating : T10AL , 250V-
DC OUTPUT +3.3V +5V +12V -5V -12V +5Vsb
MAX. A 37A 45A 21A 1A 1A 2A
Total Max output : 525
Do i need to upgrade my psu?
1 - 15 of 15 Posts
How is that PSU even 525W.. 21A?
Yes, you will need a new PSU -- a more reliable one.
I suggest you get at least a Corsair 650W if you plan to upgrade or SLI later. If not, a Corsair 550W will do you well.
Yes you need a new PSU. Any good quality 400w unit would put that 525w unit to shame.
A Corsair 450VX will support that easily. A 650TX will be perfect for SLi
for a GTX 285? I would suggest a 650TX by Corsair.
Thanks for your replies
I live in australia so i not sure if i can get those psu you show me.
I having a close look at these two psu
750W "SilverStone" ST75ZF or Corsair TX-750 750W
Either one will work just fine. I prefer the Silverstone because it is 100% modular, but it has dual 12V rails whereas the Corsair is single rail.
i have an ez-cool tornado, it hasnt put a foot wrong but it has started to rattle a bit any ideas?
GTX285 is a 183w GPU. With new dual core and other stuff, you need a psu that can do 400w on 12v. Corsair 550vx. It is a good investment for your new cpu and GPU.
Hey, I think it could be the fan that is making the rattle. I would check is ASAP.
Whats the advantage of having a dual 12V? (better for SLI)
Um.. what does 100% modular, mean?
cheers.
1 - 15 of 15 Posts
