So I finally came to a decision and returned the Titan Xp and bought 2x 1080ti FE from Nvidia. Now I never had this issue until I put in these cards but when both cards are at 100% load the PC will eventually/randomly cut power and then restart. It'll happen much quicker or instantly if I set the power limit on the cards above 100%+ Initially I thought my power supply, Seasonic Silent Snow 1050W was starting to go bad since I have had it for 1.5 years but I've never broke 800 watts usage until last month after I installed these cards
So what I have done so far is I purchased another of the same model Seasonic Silent Snow 1050w.. Apparently the power cutting off still occurred even with the new unit so my PSU is definitely not failing. Then I started wonder if it was my motherboard so I went and got a temporary one, Asus X99 Strix ROG. Apparently its not that either and I may have wasted my time RMAing my gigabyte motherboard thinking the VRMs were overheating.
I even went to thinking it was the PCI-e 6 and 8 pins power cables and pulled new cables from another seasonic PSU I was going to give to a friend. Problem still persists. Now I'm down to thinking it might be the new GPUs being faulty but just an hour ago I came across a couple nvidia.com threads through a google search on 980 Ti SLI having a similar issue. So I'm curious if it has to do with my PSU being a single 12v rail not being able to handle the stress? No power cutting off if I run one card at max
I also currently run my CPU at 4.2 @ 1.235v and both GPUs are watercooled
