1 - 5 of 5 Posts
Hey,
I've been getting some wierd problems lately, and I think it might be the CMOS crapping up or something:
If I turn off my computer and try to turn it back on after.. say, 2 minutes, it will get stuck at the POST screen. The motherboard usually counts up like C1... 12....25 ...40 ....50 .... 75..... 96.... FF
something like that.. and when this happens the LED Screen shows 50 and stops there.
My overclock is pretty stable and it happens even if I lower my clocks too, it usually works just fine, but sometimes I shut off the system and then remember I had to do something so I turn it back on after 5minutes and it gives me this annoying freeze, so I unplug the PSU, plug it back in and everything's fine. Any ideas?
Discussion Starter #5
Um, it never happened before the update, but it took some time. I mean, I updated, worked fine for like a month but then **** started happening
1 - 5 of 5 Posts
