So I get my XSPC RS360 kit probably Tuesday or Wednesday but if I really do need to test it for 24 hours then I'll wait until this weekend. I work during the week so I could only give it an 8 hour go since I won't let it run when I'm not there.
ekk um i HOPE your using distilled water. i would suggest that you ground your pc and lay some paper towels in the pc so you parts dont get wet. but in the case something happen and parts go wet just dont turn on your pc for 12-24hr ( better safe than sorry ) tap dry and thing that go wet and let it air dry.
Is the GPU in the loop? If not just don't have it in there.
Why not? how do you think they are cleaned in the manufacturing process?
Did you realize you said no need for 24hrs then went ahead and said to let it run overnight?Originally Posted by jay2nice000
no you dont need a 24 test, do a 30 min test with you always eyeing it for leaks, make sure you have a flash light sometimes a single drop of water takes time to build up. if it pass the 30 min test with no leaks then leave it on all night and go to sleep then check in the morning for any leaks. if no water is dropping then your golden
It's not recieveing power so it won't damage it.
That's what I'd do.If it lasts 30 minutes without a significant leak, then you will only have to worry about slight leaks that will take quite a while to become noticeable.Originally Posted by jay2nice000
Yeah, keeping it simple seems to be the safest plan. Just use barbs and clamps or compression fittings.The most common leaks i see around here is from damaged radiators/ defective swivel fittings.
ive had leaks using coolant all over my gfx card lol. dabbed with distilled water and dried via hair dryer good as newOriginally Posted by Art Vanelay
Make sure you cover all of the fittings with paper towel, in case there is a small leak.
As long as you are using distilled water, anything that the water contacts just needs to be dried, and then everything will be fine.
UGHHHH.
Heh, once deionized water hits anything...it is no longer deionized. So water is water. Granted it will still be better than my tap water, but it isn't like it is going to make a crust on the PCB that could cause a short.
