1 - 6 of 6 Posts
Im using a tight finger tip grip so all those humps at the right and left side of mice cut into my fingers. I love the shape of the Trust GXT 105 but it has a crap sensor.
I like how its bend inwards ON BOTH SIDES: https://i.imgur.com/bvRvoMe.png
Other mice that came close: G403, G402, Creative M04
thank you for your suggestion. the mice wont let me comfortably fingertip grip it though since it has that hump in the back.
Did you try the shape Logitech uses for G102, G203, G Pro, G305? It doesn't have those )...( sides that you like about the Trust mouse, it's instead a combination of (...) and \.../, but I think there's nothing about it that "cuts into fingers" and it's small enough for fingertip grip (for my hands). The different Logitech sensors on those mice are all excellent.
Cougar Minos X5 is similar. Also, the Roccat Kone Pure Owl Eye, although not ambi is good for finger tipping. Both are short where the hump doesn't get in the way.
1 - 6 of 6 Posts
