Do video games installations need the windows drive?
982 Views 27 Replies 14 Participants Last post by  brettjv
I'm not sure if this has been asked before, but I can't seem to find the answer anywhere at the moment. Do video games need to be installed on the windows hard drive? I know they give the option to select where to install them if you choose custom installation.
I ask because I am thinking of buying a 60gb vertex now(all i can afford) and buying a second one later in time when I can, and installing other/older games on the next one. I know I cant get much games on a 60gb drive AND windows, heck dragon age takes up 15gb already(no custom content purchased)..
1 - 20 of 28 Posts
Hi.
No, games do not need to be installed on the OS drive.
It's just like many programs: you can install them anywhere you want. Try this from now on and see how many programs you can install to somewhere other than C:\\.
Originally Posted by Syrillian
Hi.
Ok thank you very much, the answer I was hoping for! So, I take it that means I can lets say install dragon age to a second SSD that windows 7 is not on, and it will run the same as if it was on the windows drive? Does it need to be in a folder called Program files, or that matters not at all?
Yes and no. All games will need to install some items on your HD, even Steam games need some HD space. Eg saved games usually will be saved to 'My Documents'
You usually have the option to install the game at minimum or full in the custom install part and you get to select where you want them to go... mostly.
Syrillian - your a posting ninja or Im a slow typist
The Folder can be called whatever you like.
For all intents and purposes (afaik) the game will run with the same efficiency.
I install all my games on a dedicated drive.
We have the freedom to install most software (especially games) to any drive letter we want and in any folder name we want - usually. I mean, there are special programs (not games) that might need the folder name to be a certain name, but this is kind of rare.
I was wondering the same thing in a slightly different way (not sure if I am thread hijacking here) I wanted to install all my games on a separate hard drive so when I reinstall/upgrade windows I wont have to reinstall all my games but, a lot of game files (save games, config settings ect) are still on the windows drive, is there any way of setting a default folder on a seperate hard drive to windows for all these file to go?
Edit: sorry about my slow typing, it looks like my question has been answered
When something is installed on D:\\ when Windows is on C:\\, that unfortunately doesn't mean that C:\\ can be reformatted and still have those games installed when Windows is re-installed. This is because that fresh installation won't have those games installed. Err, the fresh installation won't even know they're there.
I don't know if that would work though pyra, doesn't the game still install registry files or some such in windows? Wouldn't the game not work if you reinstall windows and not the game?
Installing a game (or any software) also places it in the Add or Remove (or Programs and Features) control panel. It's literally installed into the operating system. So, if I install everything to my D:\\ drive, then reformat and re-install Windows, then that means I have to re-install everything.
^ Yes.
There are a couple of games that I installed on an external hard drive and used on more than one computer but, not all games will let me do this, I was just wondering if I could edit a config file maybe and make the games saved games ect save to a different folder, maybe not though.
I'm thinking that there's a registry entry somewhere that's telling the game where to save the games, but I don't know what it is for any of my games.
I personally dedicate a Hard Drive for Games, also saw my performance go up a few frames since that dedicated drive doesn't put up with windows' random reads and writes.
you should give it a try, especially if you have stuttering issues in your games
I know some(if not all) Quake/id Tech 3 engine games will work after reinstalling the OS. You can even copy and paste to "install" them. Battlefield 2 may have as well. But that's all I can think of that I've tried.
i have my drive partitioned documents and games on one, windows on the other along with other stuff like winrar ect on C:. It just means if i wanna format i dont have to loose saves ect
In a few words - installing games to a 2nd drive and then reformatting or changing the C drive still means you have to reinstall the games in some cases. Others not so much.
STEAM for example, handles this pretty well. Putting STEAM on a seperate hard drive - all you have to do if you reformat is install STEAM but put STEAM in the same folder on the same drive as previously and all your games will be retained.
Others work or don't work in my experience. Registry files and other dlls like to go missing.
Also of note, some games act up when not on the C drive. I know FEAR wouldn't install the expansions because of this and you have to 'spoof' the drive letter. But that's not a prevalent problem.
I keep steam on it's own HDD to keep me from re-downloading everything. Back when me and my two old roommates played WoW, we kept an up to date copy on the shared network HDD as a backup as well.
This might not be literally what you are asking for, but it might be an alternative solution that may work better for you.
In Windows 7 (not sure about Vista) if you right click on your My Documents folder, there is a location tab, and it will allow you to set the location of your My Documents folder to any location that you specify. Since this is where most Games choose to put saves, it will effectively allow your save game files (and anything else in My Documents) to exist in another location.
This is also handy if you ever wipe/reinstall Windows, because your My Documents will still be preserved (if you made the location on another partition), and then you would just have to do the above again to point it to the correct place after a reinstall.
If Vista doesn't have that feature, you could always go the symbolic link route. Which is a command line route to do the same as above.
Here's a guide on symlinks.
http://www.howtogeek.com/howto/windo...windows-vista/
If there are games that don't save to My Documents, or if you don't want to move your whole My Documents folder, you could go crazy with those symlinks and do it for only certain folders within My Documents or do it for any folder anywhere really.
Hope this helps
1 - 20 of 28 Posts
