1 - 3 of 3 Posts
my ocz vertex 450 512gb ssd died recently so I went out and bought a crucial mx100 512gb ssd so my computer would not be down while I wait for ocz to RMA my ocz vertex 450 512gb . after installing the crucial mx100 512gb ssd I ran 3d mark 11 benchmark and my benchmark scores was 200 to 300 points lower then when I had my ocz vertex 450 512gb ssd . so I was wondering if the change of solid state drives effected my scores or if it is some thing else that is causing my scores to be lower . does the kind of solid state drive you are using effect 3d mark 11 bench marks ? also I am planning on adding the replacement ocz vertex 450 512gb ssd that ocz sends me to my build to use for storage . will adding the ocz vertex 450 512gb ssd to use for storage effect my 3d mark 11 benchmark scores ?
I don't see why storage performance would be factored into your score at all since 3DMark is supposed to bench your CPU/GPU.
If I had 3DMark I'd give it a test with my SSD and clone my OS to a HDD and compare the results but I don't have it so I can't give you an answer other than it probably shouldn't impact your score.
1 - 3 of 3 Posts
