I'm not sure if it's BTX, it's the ones that have the mobo on the opposite side of a ATX mounted upside down. I have one years ago and was wondering if they are still made as I can't seem to find any.
Think cancer got it. if your looking for that unusual mobo mounting layout, look at the Silverstone Ravens and FT02 (not a fan of the 03 atm). I personally own a FT02 and will vouch for its quality. Honestly I don't remember bTX being released... their was aTX mini-aTX, and for a very short while "extended" atx.Originally Posted by Cancer
Is this what you are looking for?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517019
That's it. Is there a cerain keyword I'm looking for, or do I just have to look at each one?Originally Posted by mxfreek09
I see what you are looking for now. Here you go then:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811345013
Interesting. So the inputs are on top?Originally Posted by Cancer
Or did you mean this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163180
Yeah it's a really funky case.
The FT02 is the bigger brother of the case you linked Cancer. I don't know if you had experience working with the Raven or not (sound like you did) but from my view, it didn't cause any head aches. It was actually easier to work in than many others. The Raven might be a bit different because of the PSU placement, but the FT02 has the PSU "hanging" by the cpu/ram like traditionally, only with the whole thing flipped 90 degrees.Originally Posted by Cancer
Motherboard is rotated 90 degrees so the GPU and other "rear" inputs are on the top.
The PSU is on the bottom...at the front...rotated 90 degrees to the side.
Think about that for a moment.
It also has 2 powerful "penetrator" 180mm fans at the bottom.
Very nice case...but it will hurt your head to work on it as so many things are different about it.
Very well engineered though.
Which of the following configurations does your motherboard have?
Bigger brother?Originally Posted by th3m3nt4l
The designes are unique, but from what i've experienced offer better air cooling because of the use of thermal dynamics(maybe?)- aka heat rises so pull cold air in through bottom fans and push it out the top.
