1 - 12 of 12 Posts
Some call me... Bifford
Originally Posted by mojoopo
what fans are u using with it and wat r ur temps did they come down far from stock cooling
I never used stock, I bought OEM chips. With a little extra juice to the core my fx55 idles at 48C. Not that spectacular, but the cooler was cheap. It comes with a 90mm fan but I replaced it with a UV reactive fan from Ultra.
oh so that coolers sh%t
I wouldn't buy it again, but I won't throw it away either. It will make a good backup. If you budget is tight, it should hold you untill you can get something better.
I don't know, Tigerdirect.ca had it a month ago, but right after I placed my order, they removed it from the site.. You could Always try bigfootcomputers.com, or summitdirect.com.. Just email them and find out if they can order one in.
1 - 12 of 12 Posts
