Im not sure if this is such a good idea ive only considerd trying it with 2 gtx480s, problem is the tubes will be going upwards because my rig is flipped upside down
so upside down it looks like the liquid will get pushed in 1 hole of the first graphics card, and jus come strait out the same card without the others getting filled with liquid.
maybe using a smaller size tube on the last exit tube would create abit of pressure build up forcing the other card to fill up maybe?
if this works do you think the temps will be better than if i used the normal "series configuration"?
