I just put this system together last night and was verifying if everything was working before loading an OS or overclocking.
I have a Xigmatek HDT-S1283 with stock fan on an AMD Phenom II 940 on a Gigabyte AM2+ MA790GP-UD4H board.
If I connect the fan directly to power, it spins with no issues.
If I connect it to the 4 pin CPU fan connector on the motherboard, it does not spin, but it pulses forward randomly like it is just checking to make sure it is still there.
The board has PWM fan control enabled.
The processor has only reached 19 degrees celsius even without the fan running. Ambient temp is 20 C.
Is is possible that the motherboard is simply not calling for the fan to spin because the processor is not hot enough to require additional cooling?
Do you think I could have a defective fan or motherboard?
Thanks!
Kirk
