1 - 12 of 12 Posts
OCN,
I need some OCN-pert advice. I was thinking about upgrading my other half's Mobo, CPU & Memory currently she is rolling with a Intel Core 2 Extreme QX6850 @ 3.5GHz, Foxconn ELA P45, OCZ Reapers DDRII @ 977MHz & HD5770 1GB
Her system is used for Gaming COD MW2, DiRT 2, Work Accounts, Study & Web Browsing
Doesn't need one perse, could upgrade the RAM and GPU...
Do you have a budget?
Well a new Mobo, CPU & Ram is going to cost £400.00
Is it going to be worth it because her CPU is still rocking HARD
Code Monkey
Change the CPU cooler and up that OC, maybe, but that's about it. And a chick that plays MW2? Now I've heard everything...
Nah I think her computer needs an upgrade its pretty decent at the moment.
Just save them money and maybe you could get her a different kind of upgrade
lol JK
EDIT: Mw2 has an FPS cap of 90 is it is piss easy to hit it hey I even hit it on my old AMd athlon 4600
No need for upgrading at this time...
Originally Posted by SickStew
OCN,
Yes.......honestly though not really. She's good to go for at least a couple of years.
Discussion Starter #11
Originally Posted by loser7
Your temps are so low .. Can you OC more? No upgrade but OC more if you can.
The temp may seem low because I have offset the TJMax to 80C as per Intel Specifications for the QX6850.
What could I get in place of the Corsair H50? (I think the H70 is to big for the case)
Below is a picture of her set up
1 - 12 of 12 Posts
